I am new to EM (So to HFSS). I have used FDTD for my initial Patch Antenna simulation so I have some basic concepts. Now I need to do a fast start in HFSS.
I will summarize my situation so that it helps your suggestions.
I know how to calculate dimensions for the patch and substrate for my centre freq. Material selection is easy given HFSS has a list sufficient for me. I will eventualy add parasitic patches and play with slots and other BW enhancements to come up with a nice patch element. Finally my solution will be an phased array.
Now when it comes to Simulation & Antenna parameters,
With HFSS I am in short of knowledge in:
1) Solution Type (Which to select?)
2) Port Setup (Which to select When?)
(For a start to model probe feed I am about to use lumped port but eventually it will be feed by microstrip so I understand that I will have to move towards wave port. Any comment on accuracy of the lumped port? I mean will my Impedance BW, Gain, Pattern etc will vary drastically when lumped port is replaced some practical feed in reality? )
I guess I have lot more but I will not overflow here.
Overall If somebody could provide a HFSS design project of a Patch Antenna, I should be able to explore how things are done and base on that.
Thanks,
Soyuz
PS: My apologies for my english
