Password text box problem on edaboard website
snishanth512
Full Member level 3
Full Member level 3
India
Sometimes when I enter my username and password in the text boxes, found the following problem (which is seen at the top of website).
Password is visible at the text box instead of each character replaced by a dot.
As a result, I always click on login button.
I enter my username and password which doesn't have this problem.
Which worries me a bit.
I hope this problem will be fixed.
I've not experienced that issue, I frequently use Internet Explorer, Firefox, Chrome and Opera browsers.
What browser are you using when you experience this issue?
Can you post a screen capture and post it here?
BigDog
In the JPEG picture attached, the password field has "asdasdiew" text (which should be in black dots).
may be this happens due to slow internet connection and enter username and password before loading/running some script in the login area
You may wait for fully loaded the page and try it again.
I hope once the web page fully loaded then you can see word "user name" and "password" should be disappearing when you click the text boxes.
I ran a quick test, by typing repetitively a "x" character while the page was not fully loaded, and It happened exactly as bassa had supposed.
@Andre
Interesting, you must be a lightning fast typist? :grin:
I certainly do not have a particular fast Internet connection, 12Mb, and by the time I select the password box the page is fully loaded.
@snishanth512
What type of Internet connection and connection speed do you have?
Has your browser been slow to startup, open a new tab or load pages?
What extensions or plugins do you have loaded into your browser?
BigDog
This test was done on a (theoretically) 54MB wireless network, but once on that ocasion I was located too far from the router antenna, the signal level became too weak, yielding a performance almost comparable to a telephony network.:wink:
I'm beginning to wonder if snishanth512 may have some browser malware like V9, AVG Search, etc installed.
I seen such browser malware slow the performance of a browser down to a crawl.
BigDog
Connection : 2 Mbps.
Chrome browser.
Yes, the connection is slow.
But password text box should not allow the user to enter the text.
In the above image, even though the website is partially loaded, the password text box doesn't show the characters which I entered.
