I want to do a corner analysis along with several other variable
parameters for my design.
At present the line specifying the model file looks like this...
All I need to change is the last argument as "ff" or "tt". So I want
to give these strings as parameters from an array and run the
simulation.
Does anybody have an idea how can I do so?
Waiting for some solution,
-Pratap
Re: Passing model file as a string parameter in cadence ocea
Thanks JoannesPaulus,
The if type logic worked with a bit of correction...
(There was a single quote missing in the array declaration...)
But for passing string parameter a special syntax like "list" was required.
