[SOLVED] Parmater not Recognized in Task by Verilog
hassanzia
Junior Member level 3
Xilinx does not recognize the parameter I declared in the following task? I'm using Xilinx 14.2.
module CarrySelectAdder_GroupSize2(a,b,cin,sum,cout);
	parameter n = 4;
	parameter group_size = 2;
	input [n-1:0] a,b;
	input cin;
	output reg [n:0] sum;
	output reg cout;
	reg [n:0] tempsum;
	reg [n:0] tempcout;
	always @ (*)
	begin
		RippleCarryAdder (a[group_size - 1:0],b[group_size - 1:0],cin,
						tempsum[group_size - 1:0],tempcout[group_size - 1:0]);
		sum = tempsum;
		cout = tempcout;
	end
	task RippleCarryAdder;
		parameter m = 2;
		input [m-1:0] RCAa,RCAb;
		input RCAcin;
		output reg [m-1:0] RCAsum;
		output reg RCAcout;
		integer i;
		reg [m:0] carry;
		begin
			carry[0] = RCAcin;
			for (i=0; i<m; i=i+1)
			begin
				RCAsum[i] = (RCAa[i]^RCAb[i]^carry[i]);
				carry[i+1] = (((RCAa[i]^RCAb[i]) & carry[i])|(RCAa[i]&RCAb[i]));
			end
			RCAcout = carry[m];
		end
	endtask
endmodule
the following errors occur when I try to compile the code :
ERROR:Xst:917 - Undeclared signal <m>.
ERROR:Xst:2634 - "CarrySelectAdder_GroupSize2.v" line 54: For loop stop condition should depend on loop variable or be static.
you can't define a parameter in a task.
Use a generate statement instead to generate the ripple carry stages.
You should be able to declare the parameter outside the task and reference it from withing the task.
dave_59, will that work with a parameterized width?.
It worked perfectly. Thank you!
Although my problem is solved, May I ask how I am to use a generate statement to generate the ripple carry stage?
