sanketpatel2020
Hi!
Greetings!
I have doubts in simulating parallel plate waveguide in HFSS.
1. Two sidewalls of the parallel plates are assigned PEC boundaries. Do I have to assign PMC boundaries to remaining two faces (which are not actually sidewalls, as parallel plates have only two side walls, which are already assigned as PEC)?
2. Should it be a "Driven Modal" or "Driven Terminal" (in context of HFSS)?
3. Which Excitation: Waveport or lumped port or voltage port?
However at later stage, my aim is to simulate three parallel plates, where wave is applied to middle plate and the outside two plates are grounded.
Please guide me in this regard.
Greetings!
