alimassster
Junior Member level 3
Hi all
I wanna know by cascading DSP48 blocks if we need for example N clocks to feed multipliers with N inputs in an N tap FIR filter to calculate Y , then what's the difference between the parallel form and a single MACC based form ( if there's an equal delay(number of clocks) in both forms)?
what's the advantages of parallel implementation?
I know in parallel form we have a result in every clock cycle.
but is it because of useing pipeline or something else?
Are inputs ( not coeficients ) fed into multipliers simultaneously or one by one by using BCIN-BCOUT ? if so , again what's the advantage of a parallel form? is it using pipeline or what?
thx in adv
thx in adv
