Paralelism in RTL - request for resources
cafukarfoo
Full Member level 3
Paralelism in RTL
Hi Sir/Madam,
Can someone give some brief explaination and example for parallelism in RTL? Thanks.
Re: Paralelism in RTL
cafukarfoo said:
Hi Sir/Madam,
Do you mean concurrent processes ?
Hi Advares and Syswip,
Actually i come across this parallelism in RTL idea to improve the fmax with a digital design.
That why i bring up this topic to understand more this idea?
Thanks.
OK,
Look at this simple example:
module xor_test_seq (in1, in2, in3, in4, out1, out2);
input in1, in2, in3, in4;
output out1, out2;
assign out1 = in1 ^ in2 ^ in3;
assign out2 = out1 ^ in4;
endmodule
module xor_test_par (in1, in2, in3, in4, out1, out2);
output out1, out2;
wire temp1, temp2;
assign temp1 = in1 ^ in2;
assign temp2 = in3 ^ in4;
assign out1 = temp1 ^ in3;
assign out2 = temp1  ^ temp2;
endmodule
In the 1st module you have 3 XOR gates and the longest timing path is 3 * xor_delay.
In the 2nd module you have 4 XOR gates and the longest timing path is 2 * xor_delay.
So as you can see, you are improving timing but increasing area.
Please don't hesitate to ask again if this example is not what you want.
Tiksan,
http://syswip.com/
    cafukarfoo
Hi Syswip,
Is there any diferent between parallelism vs pipelined concept in RTL?
Thanks.
