waseemsh
Member level 2
I am using a parabolic antenna but i don't have a horn antenna to feed it.So what are the possible alternatives can i use a monopole antenna as feeder and Parabolic dish as reflector.
So, In Case what will be the feed assemly i.e the conductor of coax cable should be attached with Monopole and the ground with the parabolic reflector.
Or help me selecting any other feed assembly and what will be effect on gain if Feeding parabolic antenna with any other source.
How polarisation is set with monopole antenna as feed.
thanx
thanx
