PAR successfull, simulation fails
thepiper
Newbie level 5
par simulation fails
Hello everyone, I'm using ise 9.2i for my design, and PAR runs successfully and meets all my constraints with no timing errors, but when i run the simulation, it reports multiple warnings of all kinds (hold/setup violation...), what could be the problem?
thiagu_comp
Member level 1
Bangalore
This is possible. For example, if there is reset recovery / removal issue, this cant be found unless the specific timing for the signal is captured in the timing constraint. There is a possibility that your reset in testbench, violates this timings and a warning is generated. Can you please explain what constraints have you provided for timing and what are the violations?
thepiper
Newbie level 5
my constraint are just the basic period and offset constraints, and the warnings are
X_FF PULSE WIDTH High VIOLATION ON RST;
X_FF HOLD X VIOLATION ON I WITH RESPECT TO CLK;
X_RAMB16_S9_S9 HOLD High VIOLATION ON DIA(7) WITH RESPECT TO CLKA;
X_RAMB16_S9_S9 SETUP High VIOLATION ON DIA(6) WITH RESPECT TO CLKA;
