Hello All,
I have circular PCB of 47.6mm X 47.6mm Where i have planned to 2 X 3 matrix panel Design, which has total of 6 Boards in a Panel.
Now when I design Panel, I read most of the PCB Suppliers area suggesting to keep 10mm(2mm Slot width) Clearance B/W Each PCB, So 6mm of Base material B/W the PCB to have good Mechanical Stability.
Can Some one explain what is the reason to keep 10mm Clearance B/W PCB's particularly for Circular PCB?
Thanks in Adavance,
Regards,
Arunmaran S R.,
