PADS-Perform translation software
naveshece
chennai
PCB Design
I had designed my own Home made PCB Layout and successfully got in the copper clad..But i dont have idea about how to apply solder Mask in that PCB..
Can any one Help?
PCB Design
You may get the solder mask layout generated by the same software and print it on to the PCB with silk screen process. BTW you didnt mention by which method you made the PCB?...
PCB Design
for solder mask you can apply using screen print method or you can use UV curable solder mask ink and expose with your pattern. it is available in dry film also but very hard to find dry film solder mask
PCB Design
i am looking for dry film solder mask, please give the contact details for buying
