pads layout padstack problem
george1
India
pads to bottom layer
Hi all,
Attached picture is padstack from pads decal editor.
Pad size defined is 60 for top to bottom layer. But graphical bottom side pad (red color) seems to be smaller than top side. Is there any way to make it visible same like top layer?
Thanks
padstack
I think this could be paste layer or solder as in the attached image it shows top and bottom side having same value.
just chk the layer you have highlighted for the footprint if it is bottom layer or not.
pads-layout error
Layer active is bottom (red color)
pad stack
In the decal editor, go to Display Color ,you can change the same color to top, inner layer and bottom layer.
this will clear your doubts.
just try it.
Thanks&Regards,
S.Senthilkumar.
padstack pads
This is actually dispaly problem.the padstak whatever you created is correct.
