Pad Cell
ApTuPr
Junior Member level 1
Hello Folks
I was performing Boundary-scan cell insertion but prior to that, I need to insert pad cells. But, while executing the command "preview_dft" in the design compiler. The following error comes (shows in the snapshot):
I have tried to use the command:- set_bsd_linkage_port -port_list {ports name}. This command is used for not applying the boundary scan cells on the ports mentioned in the list. So, I mentioned all the ports for which pad cells were not found to remove the error. Then again, I tried but then it shows a warning stating Can't find ports in the top module.
Kindly help me out regarding this ASAP. I will be highly obliged.
Thanks in advance
Pranjal
