jxw
Newbie level 3
Hi guys, I'm using a really old P-CAD 2002 for my lab work and am using the Shape-based router to autoroute my board, which has several hundred pins. My ground layer is a plane layer that has 4 different ground regions made with plane region shapes.
It seems that the autorouter is only routing a pad directly on top of its ground region to ground, but there are some pads that are islanded off and not directly on top of its ground plane region. The shape router seems it isnt able to recognize that it needs to make a via out from this pad away and onto where it's rightful ground plane region is.
Does anyone know what to do in this case and how I can make it recognized where the plane segment is and route traces out to there and drop a via there?
Thanks a lot!
Josh
Thanks a lot!
Josh
