abhikuvar
Newbie level 6
- Joined
- Mar 5, 2014
- Messages
- 14
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 3
- Activity points
- 118
What are the factors that decide the output voltage of a gate driver circuit?
1. Basically I am planning to implement ADuM3223 as a gate driver for power electronic module I intend to build (https://www.analog.com/static/imported-files/data_sheets/ADuM3223_4223.pdf).
2. H-bridge topology which I am working on operates from +6V Pb-Acid battery supply.
3. ADuM3223 will be used for driving gates of FETs in H-bridge. Datasheet states output drive is (4.5-18V). I need to size the circuit accordingly for which it is required to know output voltage of gate drive signal. How to determine that?
Any help will be really appreciated. Thanks.
