smaz
Newbie level 5
Hi
I wrote a very simple counter in VHDL and then simulated to see whether it works or not. Then I sent it to the design compiler to do synthesize without any constraints. after that I made an output netlist in VHDL and brought it back to simulator it didn't work while it was a simple counter. for detecting the problem,I decrease the design to 2-bit counter and did the same story and interestingly this time it works then I changed it to 4-bit counter and its synthesized output didn't work then I came up with making the output netlist in verilog and now its synthesized output works for any number of bit.
1-Does any body know what is the problem?
2-And does anybody know which is possible to produce the output netlist in Cadence RTL compiler in VHDL format?
Thanks in advance for your help.
