Murugesh_89
Full Member level 5
I am running out of I/O pins in my microcontroller. But i need to control 24 relays. Basically i am switching the relays using ULN2803A. So i thought of using 74HC595 shift register IC to trigger the bases of ULN. Any relay can be triggered at any time say one at a time, two at a same time and upto 24 at a same time.
My doubt while using this shift register is when i want to output new value, the bits which had a state same as current state will experience a momentary fluctuation or not?
For example, In my circuit diagram, when current output state is as follows
U5(QhQgQfQeQdQcQbQa) U6(QhQgQfQeQdQcQbQa) U7(QhQgQfQeQdQcQbQa) = 00001101 01000011 00101010
and i want to give the new value as 00001001 01000111 00100010.
Here i changed the 3 bits out of 18 bits. But other 15 bits are to be maintained at the same state. Will these 15 bits experience any fluctuation or stay solid?
Thanks,
Murugesh
Thanks,
Murugesh
