Added after 5 minutes: This will not help too much, because of the large time constant. Remove the capacitor, because you have a low pass with a corner frequency below 1 Hz !!
If the schematic is correct, there must be a DC offset at the said 200 mV input, otherwise the output would be 0V DC and about 0.6 mV AC. The resistors have rather high level, but the TL072 input current is in the pA range and can handle it.
As you apparently expected a different result, you should recalculate the amplifier dimensioning.
