Outline from the gerber/pdf/dxf
k.mehta
Junior Member level 3
Hello All,
I am fairly new on altium. Could anyone please kindly suggest how can I imort a gerber file/pdf file or DXF/DWG file into PCB Document and use that layer to create an outline. If I try file/import/gerber, it does not bring anything into the work area. Any easy way to do it please. How can I then copy only online and paste on to mechanical layer16.
thanks,
keyur
honey 77
Press 'L' on pcb, In mechanical layers just enble mechanical layer 16.
And paste any pdf/ text file on PCB, just doble click on that from layers we can select Mechanical layers 16.
anilrock87
Full Member level 3
bangalore
Hi K.Mehta,
Before importing first you check all the plugins required to import are installed or not(DXP/plugins and updates).
To import gerber just open one Cam file from file menu then try to import.
DXF/DWG-you can import in both sch and pcb file depending on your requirement.
