Outband GPS patch antenna gain?
Ghost Tweaker
Member level 5
Member level 5
Hi everyone,
I'm considering a GPS patch antenna with a 4dBi gain (zenith) and a 20MHz bandwidth. What should I consider for gain outside of this bandwidth? Is the attenuation important at let's say 1GHz or 500MHz?
Thanx in advance
Re: Outband GPS fix antenna gain?
Simply feed through some bandpass filter and do not worry about the radiation at 1GHz or 500MHz.
Ghost Tweaker said:
Hi everyone,
I'm considering a GPS fix antenna with a 4dBi gain (zenith) and a 20MHz bandwidth. What should I consider for gain outside of this bandwidth? Is the attenuation important at let's say 1GHz or 500MHz?
Thanx in advance
Patch Antenna: Phase Centre and Group delay
Excuse me,
in your antenna design, did u consider the antenna phase centre and the group delay?
they have too a strong impact on the overall performance.
Regards
Lupin
