[SOLVED] OTA vs telescopic OTA for grounded resistor implementation
Basil1402
Hello.
I am designing a tunable high pass filter : the signal goes through a cap then into a grounded resistor. To make it tunable, the res is actually a differential inputs/single-ended output OTA, fed through the invert input, and with a feedback from the output to the invert input (like this)
I am using a OTA designed by a colleague, and the results are fine.
The only thing I don't really understand is the fact that the OTA is a (single stage) telescopic one (like p. 213 in Sansen). I understand it gives a higher output resistance, but I don't understand the point here.
Can someone enlight me ?
Thanks in advance.
... the OTA is a (single stage) telescopic one. I understand it gives a higher output resistance
The OTA's gain is approximately gm*rout, so the telescopic OTA has a higher gain than the simple OTA, hence provides better accuracy.
Yes, but, in the configuration I am refering to, the voltage gain is not of interest. The circuit is used to emulate a resistor, so what is important is the transconductance gm (=1/R).
What I understand is : the higher Rout, the smaller the current in the feedback branch, and, as a consequence, the smaller the chances that the feedback unbalances my differential pairs. Is this somehow correct ?
Thanks.
Ok. I answer to my own question.
I read Gray & Meyer. It's a series-shunt feedback configuration, with a feedback transfer function of 1. So the impedance of my circuit is Rout/(1+gmRout). As a consequence, my circuit acts as a resistance if Rout is very high. And therefore, a telescopic cascode OTA, with higher Rout than simple OTA, is better.
QED:grin:
