stanleystan
Banned
- Joined
- Apr 26, 2014
- Messages
- 59
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 8
- Activity points
- 0
How can you use an Oscopes normal trigger mode like an storage scope?
You can use the external trigger on normal trigger mode? the O scope will capture and save one time period of the waveform?
In normal mode where is the external trigger event start at?
On Storage Scopes, there will be an indicators "T" to let you know where the External trigger event started. So you can measure with the cursors from the Letter T to the positive or negative edge you want to measure and get a time duration
What type of time duration measurement is this called when you're measuring from the External trigger event to the a negative transition or the next pulse leading edge or falling edge?
Can you do this using the Normal trigger mode?
