cmos babe
Full Member level 4
I need a cheap oscilloscope to monitor audio signals ,digital clock,i/o pins ,Infrared stuff..etc ..what's the minimum bandwidth i should look for?
thanks
thanks
cmos babe said:I need a cheap oscilloscope to monitor audio signals ,digital clock,i/o pins ,Infrared stuff..etc ..what's the minimum bandwidth i should look for?
thanks
VVV said:The only thing that is not clear from your esplanation is the frequency of the digital clocks. These can be very fast.
Other than that, even a 1MHz BW scope should do it. But if you can, try to get at least a 10MHz one. Eventually, you will need more bandwidth.
