hkBattousai
18f4550 internal oscillator
I'm quite new to PIC programming. This morning I designed my first PIC based circuit using an online tutorial which simply flashes a led.
The circuit used the internal oscillator of the PIC. But I want to use an external crystal oscillator.
I'm using MPLAB IDE 8.10, assembly language, and the the configuration part of my code is as below :
I think there has to be a modification in the last line, but I couldn't find out what to do after a long Google search.
Can somebody help me on this?
And I have one more thing to ask,
Assembly language is quite mind boggling when dealing with complicated projets. Sometimes I see people writing C code for PIC projects on the net. What IDE they use? Does MPLAB support PIC C? Please guide me.
Any help will be appreciated.
CONFIG WDT = OFF ; Disable watchdog timer
CONFIG MCLRE = ON ; MCLEAR Pin on
CONFIG DEBUG = ON ; Enable Debug Mode
CONFIG LVP = OFF ; Low-Voltage programming disabled (necessary for debugging)
CONFIG FOSC = INTOSCIO_EC ; Internal oscillator, port function on RA6
