Orthogonal Cross Correlation
roxy1001
Newbie level 6
Newbie level 6
Bombay,India
I want to use cross correlation technique to obtain relative phase difference between Current & Voltage waveform of the same frequency.
I was reading following technique where U1(k) which is the discrete voltage across the piezo-transducer and I(k) is the discrete current. U2(k) is obtained by shifting U1(k) to the right by No samples to obtain a delay equivalent to a quadrature phase shift
where M is the sampling rate
This algorithm uses orthogonal signal U1 and U2 ..whats the significance of using U2 when we can obtain phase difference directly by using cross-correlation function of U1(k) & I(k) only ?
