Origin of Setup and hold time in Flip Flops ???
raditsme
Junior Member level 1
india
Hello All,
Can anyone tell clearly, what is the origin of Setup and Hold time concepts in Flip-Flops. Please clarify with basic concepts .
I know the general Definition like:
Setup time. . . . . . . . . .the interval before the clock where the data must not change.
Hold time . . . . . . . . . the interval after the clock where the data must not change.
one can also say that violation of these times will lead to corrupted o/p.
but again the question is same...what is the origin of Setup and Hold time concepts in Flip-Flops.??
Please explain the negative setup and hold time concepts also?
Simply put,it's because nothing can happen in 0 second. Flipping the data in master latch doesn't happen in 0 second either, and if the current source to the master latch gets cut off while the master latch is about to be flipped, only current source is a weak feedback inverter in the master latch and it's up to the master latch whether it gets a new value or retain the old value.
Look at the transistor level circuit of a flop and look closely at the electrical aspect of how the master latch is flipped.
negative setup/hold are nothing special. it's just up to the timing relationship between the data path and clock path in a flop and how fast the master latch can flip.
@lostinxlation , can u please elaborate your answer with transistor level figure of flip- flop??
