abilashjoseph
Member level 1
hi,
I am made a simple schematic design with orcad 16.2. and i am created the netlist for orcad pcb editor, "netlisting the design" is ok, no error.
but the error is in the "updating orcad pcb editor board ".
what is the problem?
in the session log there is no errors, but there is 15 warnings,
the warnings are --
#1 WARNING(SPMHNI-192): Device/Symbol check warning detected.
ERROR(SPMHNI-196): Symbol 'CAP196' for device 'C_ELECT_CAP196_1N' has extra pin '2'.
ERROR(SPMHNI-196): Symbol 'CAP196' for device 'C_ELECT_CAP196_1N' has extra pin '1'.
ERROR(SPMHNI-195): Symbol 'CAP196' for device 'C_ELECT_CAP196_1N' is missing pin 'P'.
ERROR(SPMHNI-195): Symbol 'CAP196' for device 'C_ELECT_CAP196_1N' is missing pin 'N'.
#2 WARNING(SPMHNI-192): Device/Symbol check warning detected.
ERROR(SPMHNI-196): Symbol 'CONN6' for device 'CON6_CONN6_CON6' has extra pin '7'.
ERROR(SPMHNI-196): Symbol 'CONN6' for device 'CON6_CONN6_CON6' has extra pin '8'.
#3 WARNING(SPMHNI-192): Device/Symbol check warning detected.
ERROR(SPMHNI-196): Symbol 'CONN10' for device 'CON7_CONN10_CON7' has extra pin '9'.
ERROR(SPMHNI-196): Symbol 'CONN10' for device 'CON7_CONN10_CON7' has extra pin '8'.
ERROR(SPMHNI-196): Symbol 'CONN10' for device 'CON7_CONN10_CON7' has extra pin '10'.
#4 WARNING(SPMHNI-316): Property warning detected.
WARNING(SPMHNI-301): Problems with component 'R7'. Error with component property '' and value 'VOLTAGE': 'RVMAX'.
#5 WARNING(SPMHNI-316): Property warning detected.
WARNING(SPMHNI-301): Problems with component 'R6'. Error with component property '' and value 'VOLTAGE': 'RVMAX'.
#6 WARNING(SPMHNI-316): Property warning detected.
WARNING(SPMHNI-301): Problems with component 'R5'. Error with component property '' and value 'VOLTAGE': 'RVMAX'.
#7 WARNING(SPMHNI-316): Property warning detected.
WARNING(SPMHNI-301): Problems with component 'R4'. Error with component property '' and value 'VOLTAGE': 'RVMAX'.
#8 WARNING(SPMHNI-316): Property warning detected.
WARNING(SPMHNI-301): Problems with component 'R3'. Error with component property '' and value 'VOLTAGE': 'RVMAX'.
#9 WARNING(SPMHNI-316): Property warning detected.
WARNING(SPMHNI-301): Problems with component 'R2'. Error with component property '' and value 'VOLTAGE': 'RVMAX'.
#10 WARNING(SPMHNI-316): Property warning detected.
WARNING(SPMHNI-301): Problems with component 'R1'. Error with component property '' and value 'VOLTAGE': 'RVMAX'.
#11 WARNING(SPMHNI-316): Property warning detected.
WARNING(SPMHNI-301): Problems with component 'C4'. Error with component property '' and value 'VOLTAGE': 'CMAX'.
#12 WARNING(SPMHNI-316): Property warning detected.
WARNING(SPMHNI-301): Problems with component 'C3'. Error with component property '' and value 'VOLTAGE': 'CMAX'.
#13 WARNING(SPMHNI-316): Property warning detected.
WARNING(SPMHNI-301): Problems with component 'C5'. Error with component property '' and value 'VOLTAGE': 'CMAX'.
#14 WARNING(SPMHNI-316): Property warning detected.
WARNING(SPMHNI-301): Problems with component 'C2'. Error with component property '' and value 'VOLTAGE': 'CMAX'.
#15 WARNING(SPMHNI-316): Property warning detected.
WARNING(SPMHNI-301): Problems with component 'C1'. Error with component property '' and value 'VOLTAGE': 'CMAX'.
please help
thanks.
the warnings are --
please help
thanks.
