OrCAD Layout:Edit Footprint for Circle
gurpreet312
Member level 2
orcad circle
Hello friends
I am Unable to Create/Edit Footprint for Circle.
How to Edit or Create New Footprint for LED as Circle
Gurpreet Singh
smtop footprint
gurpreet312 said:
Hello friends
Gurpreet Singh
Hi !
Please, see here !
Regards,
PTK
orcad layout circle
Thanks
A Lot
Another Problem:
I am Unable to Made Footprint for Rectangle Pins
1. BNC DC SOCKET - Height =2.6mm Width=0.53
2. DPDT Switch - Height =2 mm Width=0.53
E.g.
As per below Method:
1.Top, Bottom = Pad Stack = Finished hole size(Drill, DrillDWG) x 2
2.SMTOP, SMBOT = Pad Stack +0.13mm
3.Drill, DrillWG = Pin Lead Size + 0.3mm
By Make Components using above method Pad Stack touch each other or Crosses from Slik Screen?
How I made Drill Holes for Rectangular Footprint?
Thanks
Gurpreet Singh
how to edit footprint
Hi!
Please let me know the full component part numbers you are looking for (Manufacturer + Part number) or the links to the datasheets.
Regards,
PTK
