yassin.kraouch
Advanced Member level 2
i am usinf this optocoupler from fairchild https://www.fairchildsemi.com/ds/FO/FOD060L.pdf
FOD060L
when i connect the output to the collector ( Vo), with a pull down it is clear that the output is inverted ( when iput is 0 out is 1 ...), so if i need to connect the output to emitter of the output transistor, i need to use a pull down resistor, i don't know how is the value of the pull down, beacause in the datsheet they give us the value of pull up but not pull down,
any aidea ?
FOD060L
any aidea ?
