- Joined
- Apr 1, 2011
- Messages
- 15,203
- Helped
- 2,901
- Reputation
- 5,814
- Reaction score
- 2,984
- Trophy points
- 1,393
- Location
- Minneapolis, Minnesota, USA
- Activity points
- 113,923
The updated schematic for the 339 is correct.
It should be okay to use the darlington version of the HOA 1397. It will be more sensitive than a non-darlington. And it may give better operation than the non-darlington.
However it may also need more shielding from stray light. If you find it is too sensitive then it could help if you insert a resistor between the emitter leg of the photodetector and ground.
To get proper operation you'll probably need to do some careful adjusting of resistance values above and below the detector.
