iceblu3710
Member level 3
I took apart a photocopier and found a wonderful laser unit inside with collimating lenses and a 90deg mirror. This unit is begging to be turned into a little paper cutting or rastering laser but I have no idea how to interface with it.
The main drive IC is a custom job so I can not find any info on it. (Toshiba Louisiana 413A1) You can see the laser connected right above the IC with its POS, NEG and what I would assume is the PWM input from the IC. The brown box is a pot.
One thing of concern is lasers should be driven via a constant current source but this appears to be directly coupled to the power rails via a simple rheostat The negative leg of the laser diode does seem to go into the IC but without a datasheet I don't know where to start.
Anybody know how to go about using this unit?
