Open Access & DFII - How these differs from each other?
kumar_eee
Advanced Member level 3
Bangalore,India
openacces import df
What is the difference between Open Access & DF-II database?.. How these differs from each other?.
open access database cadence
Open access is something where u want to switch over to encounter 4.1 to 4.1 or some other version then u no need to go and import the design once again( which happens in DF-II) but not in open access it gives u the environment where u can directly swtich over to other versions effectively
And DF2 is the design frame work information interchange which is ur layout data base where u perform ur designing like std cells etc.
Bye take care
Hope u got it
Don't forget to push help button
Re: Open Access & DFII
Open access is the new open database format promoted by cadence. DFII is th older proprietary format.
dfII is "Design Framework II" from cadence. dfII version 5.1.x and earlier uses cdba database. Newer versions of dfII, 5.2.x and 6.x use OA. 5.2.x was never meant for production use. 6.x contains tools for converting cdba to OA.
With OpenAccess database you can write C++ programs to extract data from the database instead of using proprietary Cadence Skill codes. Many EDA tools start to support OA data format. This means for example you can use same C++ program to access database generated by Cadence or Synopsys.
Check this out https://www.si2.org/
