hani nik
Newbie level 6
Hello all.
I am using a CMOS opamp with power supply 0 to 3 V. The opamp is used as a buffer with the output driving a transducer input based on the signal fed to the non-inverting input. My problem is that the output clips at 1.8 V. I need to drive it op to 2.6 V or so.
I know the output clips at a certain point but I thought it would be close to the power rails. The opamp is suppose to be able to produce close to rail-to-rail output.
Is this normal?
Thank you.
Is this normal?
Thank you.
