jit_singh_tara
Full Member level 6
- Joined
- Dec 22, 2006
- Messages
- 325
- Helped
- 9
- Reputation
- 18
- Reaction score
- 4
- Trophy points
- 1,298
- Location
- Delhi , India
- Activity points
- 4,295
Dear frnds ,
I m using a circuit where a step down transformer rated for 350mA is used .
It is giving 2 windings:
a. 9-0-9 volts.
b. 0-12 volts .
now I am using following voltage regulators
LM7805 , LM7809 , LM7909 ON 9-0-9 winding of the transformer .
The controller is driving 8 seven segment displays from 5V.
and other +9V and -9V are driving the opamp section which involves 3 opamps as OP07 and 1 opamp as lm324.
now the problem is I checked current consumption on 5V supply as 135 mA when the microcontroller is running and all displays are glowing ....the current fluctuates around 135 mA as tje display values changes .this also reflects on the +9V regulator output . its value varies around 7.5 V to 8V which is not desirable .-9V regulator voltage is fixed.can anyony explain why this is happening .
one more thing when the controller is erased the voltage on 9V regulator shows 9V Full.
I am powering both 5v and 9v regulator from the same input capacitor after the bridge .
help plz .
a. 9-0-9 volts.
b. 0-12 volts .
help plz .
