I have a Saw-tooth 0-5 Volt Signal . I want to make output +5 Volt when Signal is higher than 3V and make output 0 Volt when input is lower than +3 volt .
I used Opamp 741 . I attach the schematic that i used . the output is Square Wave that is good but is between 1.5-4 Volt .
Why ? and How can i get 0-5 Volt Square Wave ?
I can fix the output by change the +Vcc to 6Volt and -Vcc to -1.4 Volt to have 0-5 Output But I don't Want to change my +Vcc and -Vcc pins and use 2 Power supply .
Should i change my opamp ? or My Design ? or Use Some IC Like LM311 to Compare Voltages ?
It is because of the maximum output voltage swing for 741, Vcc-1.5V, or Vee+1.5V, because of the internal configuration. Another thing, 741 needs at least a ±5V supply, read datasheet before using.
You need a rail-to-rail opamp, like LM358 or better a comparator, opamps behave not so well at high frequency. For digital interfacing, a Schmitt trigger gate can be used, since the signal is in the TTL/CMOS range.
That´s right. Your task is to compare an input signal (triangle or sawtooth) with a fixed voltage. Therefore: Use a comparator, which is designed especially for such a purpose.
Apart from special properties of some types, a comparator basically is an uncompensated OP with a higher slew rate. Thus I share Inforfang's viewpoint, that is well suited for a 30 Hz signal.
