expert_vision
Junior Member level 3
Op amp with 120dB PSRR exhibits weird "noise" at 60dB gain when powered by traf
I have built the circuit in the schematic bellow which seems to work acceptable when is powered by a 9V battery.
The circuit measures the current in the mains by the means of an very small resistive shunt (R20 10mOhms 20W) connected in series with the load. This will produce a small voltage signal proportional with the current in the load, that needs to be amplified. To do so I use a very performant op amp AD8551, used as a non-inverting amplifier that is controlled by a microcontroller to have 4 different amplification levels (2x, 10x, 100x and 1000x).
When the circuit is power by BAT1 (a 9V battery) and there is no current in the sensor, the output is relatively flat, which is ok. There is a little bit of 50Hz noise picked up from the mains that is showing up in the 1000x amplification level, but that is manageable.
But when the circuit is powered by the transformer as in the schematic bellow, the 1000x amplification level is rendered useless due to a very weird constant "noise".
The noise is not induced by the transformer, because if I power the circuit with the battery and keep operating the transformer near the circuit, the output is the same as in the first picture, without the transformer.
I have also tried powering the Tl431 from the battery while the rest is powered by the transformer, to exclude the possibility of noise induced by the 2.45V shunt regulator to the non-inverting input. But nothing changed.
What could cause that noise to show up only when powered by the transformer?
I tried everything and can't link it to something.
Here is the schematic:
