alexgluc
Newbie level 2
Hi, sorry in advance for the basic question but I've just started putting in practice my electronic hobby dreams. I've problem in understanding how to give power to the op-amps of the circuit I'm supposed to realize. I've no specifications about the op-amp to be into my circuit but my input signal (at V+ or V-) is an AC one with 5Hz or 10Hz frequency. I wonder if, in order to use the whole input signal (without loosing energy from it for what possible), I can use both single supply op-amps (+Vcc) or I necessarily have to use double supply ones (+Vcc/-Vcc). I've heard that in the first case there is no way to power my AC input oscillations, therefore for half of the input signal (negative part) my op-amps will not do their job.
Can someone make this point clear to me, please?
Thank you in advance.
