OP AMP - Offset Voltage Adjust not needed - what to do now?
arefeidi
Member level 4
Member level 4
probably an easy question for the experts: I have a op amp (TL071) and don't need offset voltage adjustment.
What should I do with the two unused pins now? Connect them to ground, connect them with each other, or just leave them unconnected?
Stupid question, I know - but I've never muild up anything with an op before...
Re: OP AMP - Offset Voltage Adjust not needed - what to do n
Leave them unconnected You save space and traces.
Mandi
    arefeidi
Just let them unconnected and free.
You can even cut those pins, if you are shure that you will never use that OP again:)))
hey
offset voltage is not always eliminated
you can always leave the pins of your device not connected
the device will work properly
check whether it is internally or externally compensated...then go ahead
