obrien135
Full Member level 5
- Joined
- Nov 10, 2009
- Messages
- 240
- Helped
- 5
- Reputation
- 10
- Reaction score
- 5
- Trophy points
- 1,298
- Location
- Connecticut
- Activity points
- 3,259
You don't need it. LM7171 is most likely a better choice, if you plan to intend large signal operation at 10 MHz. LM318 allow has only a few hundred mV output due to slew rate limitation. But it requires a well considered circuit layout.If I stick with the LM318, should I use an offset null circuit?
Hi Keith,
It is an LM318 with unity gain (Rf = 10Kohms and Ri = 10Kohms) and the voltage divider is two 10K's. The supply is 13.8VDC. The operating frequency is 10MHz.......
George
