OMRON PLC C2000H STL-Ladder issue
pakiboy
Newbie level 6
c2000h plc
Hello!
I am using OMRON(PLC) SYSMAC C2000H redundant CPU for some Process control application. I dont have OMRON software but i have its Hand Held Programmer.
I have to do certain modification in programming. As Hand Held programmer only support STL. I have retrived following STL instructions from CPU through Hand Held Programmer that are unable to understand me!
LD 20107
OR 20108
OUT 00200
OR 20115
OUT 20312
Although I m familar with OMRON STL and LADDER programming but afore mentioned STL are exclusively out of the way & unable to interprate this STL in form of LADDER!!
I have ambiguity in OR 20115 i.e. as after every OUT XXXXX there must be LD XXXXX but this is the only case that i have found where OR 20115 is directly coming after OUT 00200 with LD XXXX!
I would appreciate if you suggest the above mentioned STL instructions counter part in LADDER!
NB: I have retrived afore mentioned STL instructions from such system (CPU) that is running successfully for past 12 years.So there is no chances of error in these statements.
Regards
