pkaras
Junior Member level 1
I am looking for omnidirectional 868 MHz antenna that comes with tilt option and has reverse SMA connector. It seems there are only two options to choose from: W1063 and ANT-868-CW-HWR-RPS.
The first is made by well-respected manufacturer, but it seems to be designed to be primarily used with 900 MHz rather than 868 MHz. Datasheet does not talk about frequency dependency vs VSWR. I expect VSWR to be very high for 868 MHz. If that is the case, then I am left only with ANT-868-CW-HWR-RPS.
Can anyone comment on these both antennas? Is there anything better than those two?
