hfss reflection angle setup
Hi, ghaffer:
Didn't see your post for the past days, really sorry for the belated reply. Have you solved your problem?
In case you haven't cleared your questions. Below is my brief answer:
1. For all the operations done in the field calculator, you must make sure that all the variables/operators comply with the types that the calculator required which is simply, real/imaginary or scalar/vector etc and can be found on top of the calculator. For the integration, the integrand must be a scalar, thus you have to integrate the E/H field by part. That means, integrate the real part first and then the imaginary part. After you got both of them, assemble them to be a complex number. For details, please refer to the field cookbook.
2. After you got the final results as a complex number, output it as a variable. Then you should be able to plot it using Plot-Field command. I tried fast sweep long time ago. You may try it yourself to see if discrete can work or not(Should be able to work).
Regards,
