I use Novas desbussy for pre and post simulation,
In Debussy 5.3V10
I found a new feature nLint,
Can anyone share his experience what kind help nLint can do but nWave not??
I use nLint to check RTL codes:
1. syntax
2. design error, include DFT, timing loop, mismatch between synthesis and simulation and synthesis error.
And more, i use it to check my netlist sometimes.
You can build up the rule set which you want to check in nLint.
The rules you can select include syntax, synthesis, DFT, naming rule,... etc.
It can check some design problem before simulation & synthesis, but I think it
can't do coverage analysis.
In Debussy 5.3V10
"I use nLint to check RTL codes:
1. syntax
And more, i use it to check my netlist sometimes."
I don't understand the item 2. Could you describe it in detail?
