Notch filter using KHN biquad filter
CaptainSpock
Junior Member level 3
Hi
Would like to ask if I can implement a notch filter using a KHN biquad filter (state variable), something like this https://tera.yonsei.ac.kr/class/2006_1/lecture/Lect%2016%20Two-Integrator-Loop%20Biquad.pdf, at page 8. Meaning this would use 4 op-amps right? And what would the formula for the centre frequency be?
I'm actually designing a filter to eliminate 50hz ambient noise from a pulse oximeter system, open to any suggestions =)
Thank you.
LvW
Advanced Member level 5
Germany
As written in the paper you have to use a 4th opamp to sum all 3 outputs.
As the formulas show the center frequency is wo=1/RC.
