electronicslearner77
Junior Member level 2
Generally in the reverse direction region both normal diode and zener diode exhibit similar characteristics though not exactly same, then only why zener is used as voltage regulator.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Ok the reverse voltage for the normal diode is in the range of 100v. One more doubt is when the diode breaks it is generally said lot of current flows, why is this unwanted situation? Because we are always trying to produce current. please help.
