Murugesh_89
Full Member level 5
In the following image
The normal value of the signal is at 5 V and it switches to 0 V on detection. Hence the number of high to low transitions taken as pulse count.
But in the steady state, the wave form oscillates between 5 to 3V and sometimes if noise is higher then voltage transition between 5 to 1.5v in the steady state. But my waveform will go to 0V on detection.
If voltage goes below 1.8 V( say 5 to 1.5V then from 1.5v to 5v) during normal state itself then controller takes this as a pulse, but it should not be happen.
So in the steady state even if the output oscillates between different levels i dont want it to go below 2.2 V. For doing this what should i do?
Thanks,
Murugesh
Thanks,
Murugesh
