glias
Full Member level 2
hello all,
I have some problem with the ADA4898-1 which I use for my application (IR sensor polarization/preamplifier). I tested the first and second stage which seems to be OK, but when I tried to look at the output of the third stage I have a noise (about 2mV max). I'm wondering if I use correctly the op amp, in the datasheet they use it with small RF values to reduce the thermal noise, do you know if this will be the cause of my noise ? can I use a 1.5k feedback resistor when using it in non inverting stage ? I also made a mistake in my PCB : in the datasheet they said that all ground and power planes under the pins of the ADA should be cleared of copper, and it is not my case my PCB is 4 layers with integral ground plane on the layer 2... do you think it the reason of my noise ?
I also use 100nF and 10uF ceramic instead of tantalum capacitors, it may be better isn't it ?
hope that you could help me
regards
regards
