Noise issues with long cables and LCD display
mindthomas
Member level 4
Member level 4
Denmark
blog.tkjelectronics.dk
Hi all fellow electronics engineers.
We are currently working on a two-display ARM processor solution and have finished our PCB but seems to be having some issues with the cabling.
Our current configuration consists of a single SSD1963 LCD display connected by a 1 meter long 40-pin flat ribbon cable.
The display doesn't work being connected with the long 1 meter wire. Though it works perfectly fine if the cable is reduced to 30 cm.
Though the wierd thing is that the display starts to work with the 1 meter cable if I hold my finger across all the terminals?
Please see the video below and hopefully you might have a solution.
Best regards
Thomas Jespersen
