Hello every body,
If noise is in each image taken of a scene how I will let a java code assume that two images taken of the same scene are equal.Is the code taking the same color of the scene different in the two images? If so how can I face this problem ? I converted the two images to black and white before comparing them but the code is still considering them different . What if I make the condition to assume the two images the same is not that the RGB of the pixels of the first image equal to the RGB of the pixels of the second image, but I make the condition that the RGB of the pixels of the first image minus the RGB of the pixels of the second image <5 for example ?
Thank You
