wccheng
Full Member level 5
noise floor measurement
Dear all,
I try to use the spectrum analyzer to measure the noise floor of my environment. There are a vacumm pump beside our laboratory. I want to test the noise floor effect before and after the vacumm pump operation. However, I found different setting in the spectrum analyzer. It gives out different value to me. So, I want to ask yours that which setting is correct. I have the following setting of the specturm analyzer and get the following result:
(1) RBW=1.5MHz, Span=2GHz, -70 dBm @ 4GHz (vacumm pump=on)
RBW=1.5MHz, Span=2GHz, -80 dBm @ 4GHz (vacumm pump=off)
(2) RBW=1Hz, Span=500Hz, -140.598 dBm @ 4GHz (vacumm pump=on)
RBW=1Hz, Span=500Hz, -140.749 dBm @ 4GHz (vacumm pump=on)
Why are so large different? Actually, what is the setting of the spectrum analyzer in order to get a correct noise floor measurement?
Thanks
wccheng
Dear all,
Thanks
wccheng
